1G Chattering noise Pass side under
Pat026
136
Nov 27, 2016
Milford, Pennsylvania
Figured this be the best place to post it. So I took my 1g out for the summer changed all the fluids plugs and all. Took it out for a drive an here this weird grinding chattering noise coming from the passenger side underneath. It sounds like a plastic fan when it hits something or like a playing card in a bicycle spoke. It only happens on acceleration in all gears. Any ideas if this is drivetrain related?
Yes it increases with rpms it’s nonstop once I accelerate it’s weird doesn’t really sound like grinding gears but it’s coming from that side of the car
Nothing unusual with the tire I just replaced them before winter and there at around 35psi
Maybe it’s a clicking noise I’m not 100% but it only gets louder with speed doesn’t change if I go straight or turn the wheel doesn’t sound like a bearing honestly sounds like a playing card in a bicycle spoke an only gets louder as I go faster. It’s been garage kept all winter
I can post a video but i won’t be able to till tomorrow or Tuesday I left it at my dads didn’t know if I should keep driving on it or not didn’t know if it was transmission related
Speaking of noises that may or may not be related, after I replaced my clutch & PP and reinstalled my trans late last year, I'd occasionally get this strange sound from the trans area when the car was at a light or stop sign and the shifter in neutral, that was sort of like a spinning metal disc lightly rubbing against something. Could this mean insufficient engagement or perhaps something with the throwout bearing being loose?
Btw, since this doesn't really merit its own thread, I was just wondering, which gear on the intermediate shaft on an AWD DSM trans actually drives the center diff's drive gear? I'll soon find out when I finally drop the trans and open it up (lots of delays), but I was just curious. It's got to be either 3rd or 4th, and I'm guessing 3rd.
Thanks. I would have figured it out eventually:
Does the FSM mention this anywhere, or is it something experienced mechs just "know"? And is 3rd gear pretty common for most manual trans?
Sorry for the sidejack folks. Carry on!
