Changing transmission fluid on FWD (GS-T/Tsi)
RedTurboEclipse
5,613
42
Jul 29, 2002
Bay Area, California
I usually check all the tech articles/vfaq and relevant posts, but I could not find any specifically for the FWD guys.
I have changed the transmission fluid on my AWD no problem, since there are several topics/guides specifically for them. Most notable:
http://www.vfaq.com/mods/wayback/BradBauer/drivetrain/trannyoils.html
However, I was assisting my uncle change his tranny fluid on his GS-T, and as I go to use the standard 24mm socket that I had just used on my GSX, I notice that the drain plug on the FWD tranny is in a different location, and is being blocked by what looks like a suspension component. There is no way the socket will go on and give me enough clearance for the ratchet.
If I had a 24mm combo wrench it would work out, but those things are not too common at auto/hardware stores. We have looked at a few and no one carries it. (Have yet to check NAPA). It looks like a standard 15/16 size wrench is of similar size, but I don't want to risk stripping the drain bolt.
Is that the only way to do it, or is there a simpler way to make room for the tools I already have to work?
Yes, since you used a wrench it will not looked blocked because it slips right on.
But try using a 1/2" wrench and the 24mm socket, no clearance to put it on.
Well, my uncle just came to me today and said he went ahead and bought the 15/16 standard size wrench and it worked, and he was able to loosen the plug. I will have to check it out tomorrow hopefully it didn't strip anything.
Nope, its not a deep socket. It's a stanley 1/2" socket, its fairly big, so it flares out.
But we already solved the problem, the 15/16 combo wrench works great, didn't strip the bolt, and easier fitment.
