Changing Aircooler oil, to Water cooled
Lordpaxin
1,890
15
Apr 21, 2003
Jackson County, West Virginia
Hey, Im putting my jdm into my 92.
my qestion, what do i have to swap over to make the JDM watercooled like the usdm its replacing.
oil filter housing and water pipe?
what does it take to swap it,
and is there any seals i should replace.
thanks
thanks
If you have the air oil cooler, I personaly would put that on your car rather then swapping to the less efficent water-cooler.
Other then that the only gasket you need is the one between the housing and the oil pump (front cover)
Steve. :)
Thanks for the reply.
is there a good after market cooler that might fit good?
the one im using is from the galant vr4, and its pretty big, be a pain to fit it into the front of the 92. what do you think?
is it possible to trim the hoses down on my cooler i have now? and tuck it into place?
or can i whack off the metal pipes about where tehy come out. and attache rubber hoses to make fittment easier?
