water cooled oil cooler lines help!! 93 tsi
92TsiAWDT
Nov 6, 2007
naples, Florida
if anyone has pictures of how they go because i bought an engine in parts its built and all i need is to know where it goes in what part of the thermostat your help will be gratelly apreciated if you have pictures please post them in this thread thank you:confused::confused:
if there is anyone i been waiting for a reply but no answer this is what i am trying to figure out i just need to know where the line go to form the oil cooler to the thermostat
A year/couple months late, but the water line here is attached to the water neck at the location indicated in this picture, bolted to the block, and attached to the oil filter housing at the port nearer the passenger compartment.
iam sure your on a budget...but them coolers are plumb garbage...i would get a 90 housing kit and call it a day...iam running a 90 housing with the B&M 20,000btu cooler..i have a 70* differ..in oil tmps compaired to that style and i almost replace a headgasket ### i thought it was leaking...well it was'nt..it was that dam cooler..
it gos to the front one closest to the block at the bottom..then the one in the front of the oil housing go's straight up to the water pipe.. and the one at the bottom of the waterneck..closest to the head ( not the top one.) thats for your turbo.. but again there junk.
