90 oil cooler lines help
hewhoisknot
743
4
Sep 21, 2003
Flushing, New York
i went to replace the feed and return lines from the oil cooler to the oil filter... and i got hte bango bolts off... but now i can not get the bolt on the far right to go in... it's all crooked and shyt.... is there a secret method i'm missin.. i tried for 2 hrs to get it in... some help... PLACE!!!!!
Get it in without the hose to make sure you've not already botched the threads. Note the angle it's at, start over and just go slow and easy. You don't want those banjo bolts to go bango on you.
  • Wanted 6 bolt NT water pipe
    • chrisman287
