Oil cooler lines
Jollogz89
Aug 2, 2012
Burbank, California
Hey dsmer, I have a 90 gsx and the oil cooler line is leaking. I want to replace them but all I found so far is aftermarket hoses and don't have any fittings on the tip to connect to the cooler and the oil filter housing. Any suggestions? Thanks for taking the time to read my post. Anything will help.
if you need new hoses just go to your local parts store..
if the actual oil cooler is leaking, might as well get a new one!
You will not find these hoses at the parts store. They would have to be bought from the dealership or online vendor. Also the oil cooler would only leak if it is cracked which is unlikely. It is far more common for one of the crush washers or sending unit to leak. I would recommend just getting some steel braided line with the correct fittings to adapt them to the filter housing and oil cooler.
Thanks guys for helping out. Any good vendor to order or buy from. The steel braids sounds good to use.
