CF OEM Hood ?
brad98rs
134
Oct 12, 2004
orlando, Florida
I was lookin at this hood but it has the hump on the other side has anyone seen or bought this one yet, can you suggest any with the hump on the side its suppose to be on.
what does the bump go over for a 420A engine? or is it just there for aesthetics? because I thought for some reason that the bump went over the timing belt cover which is on the opposite side for the 420A, right.
The bump on a 420a is above the battery and fuse box so its just fo looks :dsm:
which way do the wiper blades go in the pics and compare that to your car to determine whether it's been flipped or not.
Its just a photoshop, they mirrored the image before the logo went on. Look in the windshield, see the hump where the steering wheel is. Kind of a giveaway. Here it is switched back the way it should be
that picture is flipped as well. the antenna is on the wrong side and you can see the dash through the window.
