CEL on - no codes
slvrspdr99
Sep 9, 2012
Middleofnowhere, New Jersey
Ok I'm stumped on this one. Check engine light is on no codes are present so there's no way to shut it off. I used my personal obd ii scanner and even the shops modis and both pull up no codes present so not being able to read codes isn't a question of equipment. Recent code was a p0300 for random misfire that only happened between 5000 - 5500rpm in 4th gear. Spark plugs and wires are new along with a valve cover gasket. It has been smoke tested and came out no leaks.
Thanks for any help
I had a similar problem with a 2004 WRX STi. CEL was on, but there was no code. After driving with the car like this for a few hundred miles, the scan tool showed an emission code that was attributed to a bad front o2 sensor. Hope this might help!
have you tried clearing the light? Maybe unhook the battery for a min and see if it goes away? Or maybe if it comes back on it throws the code its reading?
I'm dealing with a similar issue in my 98 with an H8 ECU shortly after tuning the vehicle with an OP2.0 cable and EcuFlash. I haven't resolved it yet either, but will let you know what I find once I reflash the stock tune.
Can you elaborate on your setup a little more. Year, ECU, is it tuned, what have you done to the engine management if anything?
Ok I'll see what happens if it doesn't go away. I'll try the clear option to see if that works. If not then to battery disconnection. Car is a 99 eclipse spyder 4g64 n/a mods are shift linkage related. Other than that it's factory.
