2G CEL Code: P0505
vietdude
May 27, 2004
Boston, Massachusetts
I did a DTC Lookup for this code and it says Idle Control System Malfunction. Anybody idea how to fix this? thanks in advance.
Ahh, another victim of the idle control failure. I went through this myself, and the best way to do it is to either buy a refurbished or new ISC. I know someone on here has the link for the repaired ISC, I can't seem to find it. Also try the dealer. It's kind of an expensive part, but a real easy install. Not really anyway around it. Some people leave their ISC unplugged, but I don't know how that works.
Hey jthomp, where is the ISC located?
This is the same problem i had. It kind of putters when accelerating and the occational backfire. I had the same code come up can someone please fill us in where the ISC would be located.. Thank you in advance. Some guy from the shop said it would be 500 bucks to fix.
:thumbdown
The sensor is located under your TB... lil black thing(brown in 1g). goes out alot on our cars.. Im havin the same prob.. ordered one off ebay should b here soon. real easy to change. 2 bolts .. one on eaach side.. 8mm rachet should do the trick. make sure u unplug the battery terminals u gotta reset the ECU for it to work right.
ok sorry to bring back an old thread but is it a sensor or a motor. Im having this problem also and i need to know what to get at advance auto sales or pep boys to fix my problem. My car idles at 200 or dies. same code
