ziggo0
- 774
- 9
- Oct 13, 2009
La Porte,
Indiana
As my adventure had gone today in another thread, I was developing an odd tick or knock type sound. The sound was not occuring at idle and was loud enough to hear throughout the rpm band sorta like lifter tick. I shrugged it off because I figured it was due to light weight oil (just gone done with break in). Turns out due to Permatex not setting I lost quite a bit of oil, 1/2 to 2/3rds of it. The sound came up due to low oil. I wanted to shrug this off but it did not sound like lifter tick.
So I dropped the oil pan to replace the seal with something that would last and decided to pull a rod cap...the bearing was looking worn for being so young. I pulled the one next to it (2 & 3) and it was spun...or starting to spin. Please note during this time of knocking sound I had oil pressure, it was a bit lower than usual and would raise with the r's (only went to 3k and tried to keep it low the whole time hearing this). This upset my night. I pulled 1 & 4, 1 looked ok'ish and 4 looked as if it was on it's way out as well, when the cap was pulled and bearing dropped there was metal powder in it's oil. Basically oil starvation shot my rod bearings and probably didn't help the mains.
My question is, the crank surface appears to be...un-touched? I did the finger nail method of checking and not so much as a score on the surface. Checked with a mic and it's still machined down .25mm from stock. Did I catch this early enough to replace the bearings and knock on wood?
