Cas install
dennis-1009
65
Sep 7, 2009
Loch Sheldrake, New York
I have a 2G car and a 1G engine and a 2G head. There was a crankshaft sensor on the engine and I needed to have the CAS. I purchased a new CAS sensor and a wire harness to hook it up. The wire harness that I got has three connectors. One of the connectors fits the CAS at the head. Can someone tell me where exactly these other connectors hook up to (pics would be great)? I bought the harness so that I would not have to cut the wires. I was thinking that I might have to cut the camshaft position sensor connector, since the connector does not fit on the harness, or if there is some other connector that would fit the sensor and fit the harness. I have read the instructions from RRE and it is not helping me, I need to know exactly which wires. Thanks, all help is appreciated.
well on a 2g there is the cam senser wire by camgear and another on crank for crank senser its by the balancer pully and timing cover the wire harness u bought was propy to take those two conecters int one for using a 1g style cas that sits on back of motor on opisit end of timing belt on intake cam the alot of times when doing 6 bolt swap this is most comon thing just most people cut wires and just wire in new conecter but a jumper harness is good to witch sounds like what u got
