cas electrical issue
i took the ecu out of the car and there was no signs of it being destroyed. there was no smells or any part of the circuit board showing signs of it being destroyed. is there a test that i can do to test for power going to the cas. also if the key is turned to the on position, would the cas receive power? even if the car is not running
gofer said:
Your CAS has four wires going to it, a 12v signal and ground the other two are signal wires for the TDC and CAM inputs to the ECU. To test them you'll have to pull the CAS off the head and turn it by hand, this will allow you to test the signals with a multimeter as you spin it. Both the CAM and TDC signal wires should read up to 5v as you spin the CAS, the CAM signal wire pulses 4 times per revolution and the TDC pulses 2 times.
Heres a pin out of the CAS connector going to the ECU so you can check continuity of the wires and know which wires to test for the CAM & TDC pulses.
ECU Pins to CAS connector Pins -
CAM Signal wire (YEL): Pin 2 at the CAS (4 pulses per revolution)
TDC signal wire (WHT): Pin 1 at the CAS (2 pulses per revolution)
as for the wires, what is the red wire for? is that the 12v and the black the ground?
ok, so since i got the wires correct, could i use a test light and put it in the male connector for the red wire and the negative from the test light to the battery to see if there is an electric current when i turn the car on?
Could I run a wire from a 12v source to the cas instead of using the write harness?
