2G cars missing bad at full boost
96Clipse4U
Mar 7, 2004
Lexington, Kentucky
yes i have a problem with my car i have my boost set on 18psi and when i go wot and it hits full boost it starts to miss real bad so i bought new plugs and magnacore 8.5mm wires and its still doing it i dont know what it is can u guys help
You need to be more specific with your problem. Judging by your mod list, it seems as if you need a good tuning but only a logger can tell you that. Id bet your timing is being pulled. The reason is, 550 injectors are WAY too small for what your running judging by your mod list. I hope you have a logger? If not get one, and do a 3rd gear log at WOT and post the results. Id bet money your running way lean :talon:
hakcenter said:
Replace your coil
Good guess. My coil pack went bad, and i was missing under throttle as well. And please, get some bigger injectors.
Just like my buddy who SWEARS up and down his car runs fine with 550s and a 60 trim. :confused:
Mine is doing the same thing. All I have is K N air filter new plugs and wires. When replacing the wires I noticed the coil pack was burned up on one of the outlets. I replaced the coil pack and the same outlet is turning black again. I also smell gas really strong when the car is running inside and out. I don't know where to go with this. Any help would be greatly appreciated.
There's a guy in utah who has run a couple of 60-1 turbos with only 550 injectors as well as others. They may be running on the edge but the still work. He's ran an 11.6 with it so don't knock unless you know.
I think it could be the coil but not for sure.
