Cars missing?
95whitegst
537
Aug 14, 2009
lancaster, Pennsylvania
So I changed my valve cover and the car was running perfect before and after I lit new spark plug wires in and now it misses like crazy and idles like crap any ideas?
Could be that you have your wires backwards, or there not pushed on all the way..
All that stuff is good I just did the wires because the car was running fine before just upgraded plugs
The plugs are oem plugs from mitsubishi and I only took off the hose that goes to the intake and the one in the back of te valve cover but there both back hooked up
does anyone have the oder in a diagram or anything
its still 4321 on the valve cover and 4123 on the coil right?
Your firing on the coil pack is 4-1-2-3 from left to right when you look at it from the driver side looking at the ciol pack. And on the head is 4-3-2-1 from passenger to driver side. #1 is the front of the motor, and that is your timing belt side.
all fixed guys thanks i just put some of the gel on the ends pluged them back in making sure they clicked and now it idles fine im about to head to the gym so we will see how she drives
  • Wanted 6 bolt NT water pipe
    • chrisman287
