Crazyjoker77
- 159
- 2
- Oct 9, 2004
Medicine Hat,
AB, Canada
Car has not been driven at all in probably 4 years and the little over 1/3 tank of gas is probably almost 8 years old. Car has been stored in a temp/humidty controlled envoriment the entire time.
1. Thinking I should get that gas out with some fresh stuff.
-Should I stick a small tube down the filler and sypon it out?
-Pull off the return line off my aftermarkter FPR and run a temp hose into a bucket and force the pump on with dsmlink?
-Pop out the fuel pump access cover under the rear seat and bail it out?
*I will be changing the fuel filter after I get it running as I already have one laying around.
2. Change the oil and oil filter.
3. reinstall my Hallman MBC i stole and put on my ST205
Any other thoughts to keep in mind before I exciteldy turn the key for the first time in almost half a decade?
