2G car wont stay running
thesmartestyet
74
Aug 11, 2007
coghlan, New York
my car was running great i just did the head gasket but today went to the gas station filled up went to start the car idled at about 600rpms and bounced around for about 10 seconds then stalled out so i tried to rev it a little bit to get the idle up it went up to 1500rpms then died i can not drive it at all riight now i need some help!!! i plan on taking a look at it later today but anything that i should look for or even anything you thing it could be just let me know just looking for clues to the maze
Could also be your CAS flaked out. When mine was dying, it didn't throw a code until it "un-fuxed-up" and worked for a while. When it was acting up, I couldn't get it to rev past 2k, and it would spit black, fuel-laden exhaust. My fix (on a 2gb) was wiggling the CAS plug (until of course I got a new sensor). Not sure how possible wiggling the plug is on a '95 with the sensor tucked in under the intake cam gear.
Or...it's something else.
ive never had a problem with gas from there so i doubt it could be that but i guess you never know
i just was out messing with the car one of the intectors wasnt even pluged in (lets hope that was the problem but i also checked all the other plus but my bat died so right now its charging i will update you later and let you know whats happening
