Car won't start, got it limited to two things.
whitetiger777
80
May 4, 2004
Aumsville, Oregon
My car is getting fuel, getting spark, and my car won't start. I figure either my timming belt jummped a tooth, or my ecu is fried. How do i check these things?
Compression test.
nobody jammed anything in you tubo inlet to laugh at you while you try to figure it out
LOL A buddy and I did that to someone at school
Ummmm, ok, barrowed and ecu from a friend and the car still won't start. I'll try a compression check tomarrow.
Spoolin4Ever said:
What happens when you try to start it? :coy:
It just turns over with out starting.
and for the compression test I got
Cylinder 1 .......85 psi
Cylinder 2 .......85 psi
Cylinder 3 .......85 psi
Cylinder 4 .......93 psi
Also when I pulled the number one spark plug, it was damaged like either something hit the prong, or it got so hot that it melted. I'm also not a 100% confident in the compression test. The tester had to be screwed into the head and with the spak plug holes being so far down, I'm not sure if it was tight enough
If you're worried about the timing belt skipping a tooth, this is how you can check it.
http://www.vfaq.com/mods/timingbelt-2G.html
Take the upper timing belt cover off and skip down to #8(Set your engine at TDC). After you read that, pay close attention to figure #3 and #4. You're not changing your timing belt so just do the above. Like the site says, you will more than likely have to rotate your engine by hand. Just turn it clockwise though.
If the timing marks don't line up, then you know you have a problem(skipped a tooth, etc).
Good luck
