when i start it it goes to like two grand
EVIL EAGLE RT
78
Nov 7, 2007
ST. LOUIS, Missouri
ok so i posted a few days ago about buying a car well i bought it and repaired it. but the problem i have is when i start it it goes to like two grand and then dies, but if i feather the throttle it will stay running and when i do that it has a vacumm leak it sounds like.
What does it do after it warms up? Could very well be a vacuum leak. Could also be a coolant sensor or TPS going bad. How long does it take to reach a steady idle?
sounds like vac like or isc check all the vac lines around the throttle body and check the coolant temp sensor
