2G car won't fire
spoungbob
Jan 6, 2010
Chatsworth, Georgia
Going down the interstate, the car just shuts off. Now, sometimes the car will crank, sometimes it won't. Any ideas on what it might be?
I just got done doing a head-job on the car and the motor would turn alot before cranking. I took it back apart and checked the timing again. It's okay, so now we'll go out and check the compression.
Okay, the car isn't firing, but I put the coil pack on another car, and it started great.
Sometimes I can't get fire to the coil pack. I have changed the relays and the cam sensor. It still does the same thing. Sometimes I can get fire to the coil pack, sometimes I can't. Could it be a short in the wires, or does this sort of thing happen on these kind of cars? Any ideas? Thanks.
Its on the intake manifold, a long rectangular plug.
Also have someone push the electrical plug on the coil. I went crazy trying to figure this out on my dads 97 altima. The whole time it was the connector.
Okay, a 1998 Eclipse, double over-head cam 2.0, the car will start and run okay, then the car starts running rough, and dies. Then, it will not start back, until the car sits for a while. Any ideas?
More info would help... Is a CEL illuminated? If so what?
Does it start running rough when you get on the accelerator or does this all happen at idle? There are a lot of things that could cause symptoms like that.
Check the MAF (make sure it's clean). Also check the front O2 sensor. If you have a boost leak leak it would run poorly. Is air getting into the intake after the MAF i.e. is there a leak after the filter housing/MAF? Check to make sure the fuel filter is clean. The fuel pump could be dying. Check the compression... The list goes on...
Start with the MIL. Is there one on and if there is you can a manually retrieve the code by jumping two pins at your DLC
This sounds as if your ect is telling your pcm that is is -32 degrees outside and delievering fuel to your cyclinders like crazy. Do you have access to a dvom and a repair manual? Voltage out of Range and DC voltage tests should giude you into the right direction
not trying to steal the thread. BUT..
my car ran fine yesterday. and now it wont start and when i play with the throttle and hold it at like 2k. it smokes black smoke baddd. it runs rough!
but it wont idle, let alone start up and stay idled for more than two seconds by itself.
i checked for boost leaks. nothing
i changed the crankshaft sensor. still crappy.
changed the o2 sensor.. STILL same thing
changed the plugs.
checked for spark.
clean and checked the MAF.
checked the fuses.
i looked over all plugs and wires. everything seems right and connected.
I'm gonna try to change the ECT tomorow. but what else could it be?
HELP ME =(
I need my car for work. and this isn't helping me hold my job...
What I did was change the EGR valve and the little pipe that runs to the back of the head, and it starts now. You have to turn it over for a minute and then it will start. Any idea why you would have to turn it over for a minute or two?
Yes I have checked fule pressure. Even took the fule pump and put it in another car and had no problems. Any more idea's ?
Ok. I had the car in the shop last week and no codes showed up to be bad on the car. So what could it be?
