Car will not go in gear help!!
96_AWDtalon
66
Nov 22, 2008
brookpark, Ohio
Alright, me and my friend just put together his 92 talon and filled it up with fluids yesterday. The car starts and everything, but when we tried to bleed the clutch there was very little pressure in the clutch pedal. We kept trying to bleed the clutch but very little improvement was happening. So, then we just turned on the car to see if we could get it in gear and there was no luck there, it would not go into first.
It would help if any of you could come up with any reasoning why this is happening that would be great! The only things I can think of right now are that I have a bad slave cylinder, or I noticed that the adjustment rod on the clutch is all the way out and maybe it needs to be tighter?
Thanks in advance for any help and if you need more information just say something.
