car stalling at stop signs!! also idle keeps falling to 500 and back up to 750 and th
eclipse0508
270
Nov 17, 2003
Plattsburgh, New York
i have a 95 eclipse gs with only a short ram intake and exhaust. today my car wouldnt start and when i got it started, it would stall out or almost stall out whenever i stopped. i was told maybe fuel filter but im not sure on the process to change this. any help would be appreciated. thanks :dsm:
The Idle air control motor might be causing this. Try to test it or have it tested. It is located on the throttle body below the tps. There is a test in the haynes manual for these cars. Happened to mine... ;)
reset your idle speed. Do an oil change and new plugs. Run some of that fuel injector cleaner through your tank. Clean out your throttle body and battery terminals. You have to take extra care of your car man. especially they way we drive.
If that doesn't work take it to the dealer and let them diagnose it.
Dont take it to the Dealorship(stealorship), If anything just take it to your local mechanic.
But look into the IAC ( Idle air controll motor/valve) I think it was like 50 bucks but it fixed it. What is an ISC??
