Car Sitting
97tal
52
May 13, 2012
Raritan, New Jersey
Im using this car as a project car and will not be used as a daily driver at all. So basically Im wondering if I have to stabilize the gas or any fluids in there since it will not be driven until Im done with the build. Thanks
If you plan on taking a year to build the engine then poor some fuel stabilizer in it, otherwise you should be ok. I've let engines sit up for well over 6 months and they had no problems starting. All of your other fluids should be fine.
I would drain the tank and use the fuel in whatever you currently drive or for lawn and garden equipment.
