Jeff99GS
- 1,869
- 17
- Jun 27, 2006
Cleveland,
Ohio
Man I need HELP!! My car Is stalling out all the time now....if I go up a hill or try to get on the gas it just dies. It just Fades out and quietly stops running like the fuel pump shuts off. Is my Fuel Filter clogged? I hear some people on here say they never get clogged. Are my injectors bad? could it be my ECU going bad? The car Is also making this funny popping sound at around 2000rpm free rev and it is lean the whole time i'm reving it at 2k. if you click the link there is a sound clip of the car reving aroung 2k and popping.
http://www.youtube.com/watch?v=lQ5_pblOw0I
I already changed the plugs, wires, coil, fuel pump,
Should I change the filter and rewire the fuel pump?
The coolant was coming out COLD?? does that mean the water pump is bad? I see the rubber O-ring sticking out around the pipe and its loose. What holds that pipe in place? Its the hard lower coolant pipe thats down by the AC compressor. is that hard to reapir, and do I have to do the water pump too?
