Car runs better but still needs help
nick
154
Feb 13, 2006
Edmonton, AB, Canada
ok, so I got my run a bit better but still runs rich. What would be the basic setting on the safc for a 1g car with 2g mas, some says difference is 17% and others 25 %. What would be a good start. My car has 16g turbo,stack injector,stack boost 10 psi.My question is how do you adjust it from the the safc1 settings.
1. HI-THRL Right now set at 0%
2 LO-THRL Right now set at 0%
3. TH-POINT Right now set at Lo 30% and Hi 80%
Please guys help me out. Thank you
With the settings at zero, the safc will not be making any adjustments. These cars are set up to run rich under boost from the factory, because it is safe for the engine.
As long as you have a wideband to monitor the air to fuel ratio as you drive, you can begin to remove fuel from the HI throttle setting (negative values). To stay on the safe side, you should go no higher than low 11's while under boost.
