Car Running Lean - Why?
90gsxmesaaz
Jun 17, 2005
Mesa, Arizona
As you can see in my Vehicle Profile I have an upgraded fuel pump, RC 550, injectors, 2G MAF, FMIC, Buschur AFPR, 56 trim AGP Turbo, and 3 inch full exhaust with high flow cat. In trying to tune my car I noticed that my car seems to run much leaner than other people. When trying to set my low fuel trim I have to have my low settings at 1000 RPMs to +15 just to get it stoich. Most people with the injectors and fuel pump that I have usually have to use negative numbers on their low settings. Any idea why my car is running so lean? I have my base fuel pressure set to 40psi (with the vacuum off and plugged). Any ideas would be great! Thanks!
Your 2G MAS is reading about 33% less than a stock 1G MAS would for the same airflow. Your 550s are 22% larger than stock, so you still have about 11% to make up to get back to even - that's pretty close to your +15.
M
I did not realize that the 2G MAS reads about 33% less than a stock 1G MAS. That helps a lot! Thank you!
