Car Problems Again
Laser92Rsjc
Aug 13, 2007
conifer, Colorado
ok first off my car it isnt in tip top runnin condition since its been sittin forever and i just got it fixed and got a new turbo on it but the first day it would fly down the road and now it seems like its gettin no boost. Ive tighten all the hose clamps and mabey i was thinkin cuase not runnin real well it dosent want to hurt itself boostin cuase it has a lil engine noise when im at wop it just seems like no enough oil is gettin threw or to much ??? but Other Wis im stomped
Sir, you sound like a retard.
Okay so you dont have a well written post.
But besides that do the boost leak test and make sure everything is connected properly.
Is the "new" turbo you put on actually new or is it just new to you?
I got it used its a 16g and when i would put it in 3rd from coastin at 40 and just spool it the first time it would just suck u to the seat and gain speed preety fast something proably is lose or the hose on top of the turbo proably needs a new gasket cuase its proably leakin air when i floor it cuase i cant see no boost itll move when i gain speed like to like 7 but by that time im allready 10 over the 55 speed limit
NO experience with the 16g but.....with my 14b it 'stopped' boosting one time and I couldn't figured it out....it turned out to be the waste gate actuate rod little clip broke off and the rod popped off the lil nob that holds it on.....Not sure exactly how a 16g is set up...but if its the same...worth a look
EDIT: IGNORE!!! Didn't see the it will boost 'like to like 7' comment
boost leak test should be the first order of business. 99% of the time it turns out to be a leak somewhere. since you said you just put in a new turbo, I would suspect the j-pipe is loose or the manifold is not tightened on the turbo. could even be the intake is loose. boost leak test will help you out tremendously.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
