Car move slightly when I start it in gear
anomalyinva
211
Aug 12, 2003
I run a Fidanza/Feramic setup. When I originally got the car started it did this, but much worse. I used a power bleeder to rebleed the hydraulic system, and it went away. Now, a week later, it's back. I press in the clutch, put her in gear, and turn her over and she moves a bit. Any suggestions? I seriously doubt bleding it again will help as I ran an extra qt of fluid through last time to make sure all the air bubbles got out.
I fixed it. I adjusted the master cylinder adjustment rod. It was 3 full turns until the car started shifting good again. Now, where should the engagement point be? It's still starts RIGHT at the floor.
