Car is hesitating now!!!!!!
DaOnE51T
88
Jan 17, 2004
Queens, New York
A few days ago I bought a 1992 Laser RS Turbo AWD. I bought the car with a 3in downpipe, high flow cat, and Thermal Research and Development. The car came with a turbo XS MBC and boost gauge. Yesterday I change the oil to 10w 30 Mobile and NGKR BPR6ES spark plugs(gapped 35). The car was running like a champ boosting 15psi. Today I cut up the air can(stock air filter) and removed the silencer. Now it is hesitating at around 4,000-4,500RPM's during WOT but when you slowly punch it is fine. I have been reading the forums and thought I might have the so called "fuel cut". So I removed the lower honeycomb thinking it would solve it but it did'nt. Has anyone ever experienced this? If so what was the solution?
i know it doesnt sound appealing, but try and turn down the boost a little (this may help) .... upgrade your fuel pump and rewire www.vfaq.com (you can use this site for all sorts of stuff)
Good Luck
Brandon :laser: :talon:
You may need to adjust your ignition timing. Just an idea.
Seems like since it started hesitating after you cut your airbox, it sounds like a air/fuel problem. You may need to hack your MAF to richen it up a bit.
