car is dumping ALOT of fuel... need help
97GSXCU
Feb 3, 2005
HP, New York
I bought yesterday a 97 GSX. 85K miles.
It seemed FINE when i was testing it there, no check engine light or anything like that. As im driving down the road the car has no power at all. So we pulled over and noticed the main hose that comes from the turbo was disconnected from the motor. so we tightened up all the clamps we could see.
i then continued drivin and noticed the car had a fair amount of misfiring and hesitation when stomped on so i thought it was bad gas so i continued on (NO check engine light). I put 20 in gas and 20 miles down the road its on E!!. We then stoped at a rest area and checked things over and nothing. The check engine light did however come on at this rest area. i thought it had a gas leak but it isnt leaking a thing. Iv been trying to think of everything it could be and we havent found anything yet.
So we realized it was dumping wayyy to much fuel into the motor and that was the reason for it runing super rich. the problem is why is it runing rich. so i did some research and found the original owner of the vehical (it was repoed from him) and we called him. he said that he had an aftermarket IC, manual boost controler and a few other mods. he noted that he had it dyno tuned after he performed the mods. When i bought the car it had NO mods at all totally stock. IC was the factory side mount no Boost Controler or anything.
now for the important stuff,
I took the car today to see what codes were active. The guy said it was sometihng with the MAFS malfunctioning or something. he noted that all values for anything related to fuel were at 0 and were not working correctly. he said that the ECM/PCM was in a "limp mode" as he called it. he said basically the ECM didnt know what to do and set all values at 0.
Does anyone know what the problem is?
i was thinking either a bad ECM or a bad MAFS but im no expert.
I did my best trying to give as much information as i can but if anyone needs anything PLEASE let me know so i can get this squared away. I can take pictures if needed also. thanks alot!
Well you should check the most logical problems first. If the MAS is not sending a good singnal to your ECU then I would first check for cuts in the wires. If you do not find cuts then take off the MAS and look into it and see if the honey comb parts are not mangled or really dirty. If the honey combs do not look mangled or dirty then it could be that the MAS is just faulty or the ECU is, either way you will need to find donar parts to trouble shoot the issue.
He said that he had an aftermarket IC, manual boost controler and a few other mods. he noted that he had it dyno tuned after he performed the mods. When i bought the car it had NO mods at all totally stock. IC was the factory side mount no Boost Controler or anything.
How was the engine "tuned"? Did you find any evidence of hacked wires from an AFC? If so who ever pulled the AFC out could of not reconnected a wire or connected them wrong.
Any way, I was just putting up some likely ideas.
Second look at this post.
It seems highly likely that some wires were not reconnected from an AFC that was once in the car. This would account for 0 signal going to the ECU.
thanks alot it seems very logical that this could be the problem. i do recall now the past owner telling me that he had an AFC hooked up to it. where does the AFC hook into the car and where should i be looking for the problem? it looks as if the whole car was taken apart rather quickly. it has a compustar FM pager alarm that does not seem to work either but that is a different problem all together. im gonna look for broken wires today after school and i will let you knwo what i find out. thanks alot for the help so far!
thanks alot guys for the help. removed the side panel today and looked for loose wires. found one almost instantly. it was a blue one and i reconnected it and it worked like a charm. no more sputtering, or flames car runs great. so i decided to take it for a ride and i blew the drivers from CV axel out so im gonna replace both from CV axels tommorw (if the parts come in like they are supposed to) thnaks again ill let you all know how the CV axel thing goes down...
