dumping fuel
joe sobo
846
Dec 30, 2007
stuart, Virginia
ok. i did a complete engine rebuild and got the car running, but the car vibrates bad and when i go to hit the gas, it wants to stall , so i let off the gas and it will idle but horribly. i decided to pull the plugs and see that they are sturated with fuel. i know the ecu is good, cause i just took it out of a running car. i bought the mas used from this site and it worked fine before i rebuilt the engine. i searched and no one got a real answer, so i hope some one can help me out
Everyone is going to suggest you to do a boost leak test as well as check for vacuum leaks.
Are whatever injectors you are using properly compensated for?
car is bone stock with a blt done with no leaks. also i did check all the vacuum and its all good
  • Wanted 6 bolt NT water pipe
    • chrisman287
