ineed alot of help
95dsmgst
Mar 19, 2006
miami, Florida
ok guys i cant figure it out maybe you can. i have a brand new alternator was a brand new battery. Car sputters goin up the rpms and sometimes it revs normal. i have checked al circuts and wires and grounds. everything is where it should be but im freaking lost. if u guys need anymore information ask and ill give u as much info as i can.
thank u very me
havent done that yet but what i need to figur out is why my car is drianing my battery so bad i cant find any shorts possible. i like the tester
fixed the sputter goin up the rpm range. balance shaft not timed correctly and cams were also not timed correctly. now i have to figure out why my alternator or battery is messing with me. thanks
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
