car floods
wevo1985
35
Oct 8, 2008
kingston, New York
hi, i have a '93 eagle talon tsi awd. the car has a fuel problem. when its cold it wont start easy and if it does it stalls soon after. also when driving at times the car will flood and start bucking and loose all power. has anyone else had any problems like this?
thank you
martin
new plugs and wires, gaped at .023, only about 1k on them. ill swap out the fuel pressure reg and see if that helps.
Sounds like a normal Fuel Regulator problem.....or a cold start injector but I don't think DSM's have that.
sounds like a good ol' fashioned vacuum leak for that also happened to me. Found a crack in a vacuum line from the INT manifold to the evap canister. Flood me out big time since it was sucking in more air than needed.
Cut that bad section out and goodbye flooding...
(How could that thing run with a .023 spark plug gap???..LOL, with .23, that's almost a 1/4" gap there and that would take one hell of a charge to cross those gaps..Blow the head off for sure...Sorry, gotta do a little razzing there...)
-DSM
i already have all that removed and i gaped the plugs at .028 and its no different. im going to look into the safc and see if its wired up wrong. i didnt install it but its a possibility that it could be that. ive also played with the settings and didnt get different results.
You might have a bad fuel injector or two. If its leaking youll get to much fuel. Check fuel pressure then let it sit for a while keep checking your gauge if it drops then you need new injectors.
the problem just recently started and ive had the cams for awhile. it started happening and i though it was to big of injectors so i put smaller ones in and still have it. i dont think its timing related cause sometimes the car will run fine.
im going to pull the safc out this weekend when im done with the cage on my evo and see how it runs then
