car dies wont start injectors click?
90awdt
Jan 3, 2006
hd, Connecticut
i have a 92 built talon. went to the dyno today and made about 640 horse. car ran great on at the dyno brought it home and went for a ride, i was doing a 3rd pull then car shut off and wouldnt start again. i pulled over and popped the hood and the injectors where clicking. changed the cam angle sensor didnt help. i disconnected the battery for a few minutes, reconnected it car fired up driving it back to my house and it did it again?
mods
ems
aeromotive pump
msd ignition box dis 4
need help bad!!! trying to go to the track friday.
john
Open up the ECU and see if the caps are bad. I worked on one that did what I think you are describing and it had a hole burned through the ECU.
Also, I would try the fuel relay that's located behind the right bottom corner of the ECU. The next time it doesn't start, unplug it and then plug it back in; if it starts, get a different one.
