Car dies when grounding timing through link
gsexxx
166
May 4, 2012
Minneapolis, Minnesota
Hey guys, I have a question regarding ignition timing. I dialed in my 1650cc injectors and at idle everything looks good except my timing varies from 7*-17* at idle. Before dialing in my injectors I verified that my ignition base timing was at 5* using a timing light. Now, when I attempt to check timing and check the ground timing box in link, the car dies.
When I start the car with the timing grounded, the car dies as soon as the front o2 cycles. I have read that it is normal for timing to bounce around during idle but 17* seems a little high. I have also read that the car will run rough when grounding timing through link, but it shouldn't die.
Has anyone experienced this issue? Thanks in advance.
I was just curious and didn’t want to open a new thread 😅
But yeah, I didn’t see the last seen status so now I’m not to expecting an answer
Thanks😄
If you have an issue, start a new thread and provide as much info as possible as well as update your car profile so we know what to diagnose
Like if you have a 91 6bolt in a 97 with only the cam angle sensor.. that's a big thing to note :p
