David199619
- 51
- 12
- Jul 19, 2012
East Bangor,
Pennsylvania
Hello everyone, I drive a 98 Eclipse GSX. Today my car seriously took a hit. Mine doesn't have too too much done to it, just things like the 16g evo turbo, fmic, 3" exhaust, hks bov, wastegate, k&n intake, things like that. Well today I drove to my friends apartment, and everything was fine. I started to leave when I noticed that I had almost no power. There is a sputtering sound whenever I try to move the car. The car is running terribly at idle and cycles from 500 rpm to 1200 rpm. The fastest I got it to was 60 but drove it because I needed to get back to my apartment. There was no check engine light and I ran a scan tool on it, and there was no issues. I drove it to my school (I recently started going to UTI) and my instructor found a vacuum hose that blew off so we fixed that but it didn't change much. He checked the spark plugs and found they were turned pink, which he told me meant that the car is running lean. When I was showing my friend what I meant by the sputtering, there was a LOUD backfire, and I got the check engine light on. I ran a scanner on it and turns out that cylinder 2 has a misfire. I am definitely going to be changing the coils, plugs, wires, fuel filter, and probably air filter (I was going to do this soon anyway, along with a timing belt even though the timing belt isn't needed yet). Should I be changing anything else? I'm not sure if it has the stock injectors or not, but I need to know if I should get injectors or fuel pump or anything like that, it felt like it had a lean misfire at first before the backfire incident. Someone give me advice please?
The scan tool only produced the misfire code, and no I don't have a wideband gauge, but I am getting one tomorrow or on Monday for tuning purposes. (My friend told me to get the Aeroforce Interceptor, and if I do he can get me one probably close to half off considering where he works)
And yes it is my daily driver, but I have a back-up car so it won't be moving with the misfire haha.
Edit: I'd thought I'd mention that even though it is running like crap, the boost gauge somehow read 15-18 PSI in first gear before the misfire code a few times, which is crazy considering it never read anything even close to that before.
