Car acts like it has a rev limiter at 3500 rpm
jayfr76
Jan 29, 2008
Hewett, West Virginia
95 eclipse rs. Ok the problems started a few weeks ago. It does this intermittantly along with an eratic idle. When I am on the throttle no matter if in gear or neutral if I go past half throttle above 3500rpm it starts bouncing like theres a rev limiter there. So far I have replaced the TPS and IAC. I Checked the vacuum lines and the cat. It has an msd coil pack and ngk platinum plugs. Its the 420a platform so I dont think the other threads on here that I read can help. Can anyone tell me what it might be. Helppppppppp
What were the last things done recently to the car before the problem first showed up?
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
