can't take off turbo oil line
tkhaab_94
262
3
Aug 1, 2009
sacramento, California
I can't loosen this bolt for the turbo oil feed line near the oil filter housing.
(picture from plymouthlaser.com)
Do I need a certain type of wrench?
When I use a regular wrench it feels like it's going to strip the nut.
I'm trying to take off my turbo to put on a evo 16g when I get it.
You need a flare nut wrench that will grab it from more than just 2 sides. Otherwise you really run the risk of rounding it off.
Oh. Ok. Well, I will try to buy some when I get the chance to. Do you know the size of the nut?
Whatever fits on there with a normal wrench. Probably a 10mm or 8mm. They are double ended so its only 1 wrench.
