Cant install AWD fuel pump assembly
okm12346
565
22
Dec 3, 2007
Chicago, Illinois
Im about to finish my AWD swap and I cant install the fuel pump assembly. The problem is in the o-ring seal around the assembly. I lubed it and I tried every possible way to install it with no luck so far. The rubber ring either gets pushed in or gets squized out when I try to push the assembly in.
I tried both ways - the o-ring installed on the tank and then installed on the assembly.
Everything I read doesnt mention anything about reinstalling the assembly. It just says to do things in reversed order.
What do I do wrong here?
I had this same problem, took me several tries. Eventually lubed it up enough. You may have it too bloated or stretched and will have to buy a new seal. Good luck.
