cant get my car running!!!
newtodsm's
142
Jul 9, 2009
waterford, Michigan
ok i have a 96 talon with a 6 bolt turbo swap. i have the 2g automatic transmission. i just recently took it to a trans shop. they replaced the torque converter and pump. now my car idles great but as soon as you put it in gear it dies. once in a while it will run for a second a shake real bad then die. i have replaced the speed sensor on the top of the trans, the pulse generators. i have checked for codes and nothing comes up. i have also done a boost leak test, changed plugs with ngk bpr6es changed fuel filet and wires. i am all out of ideas. any ideas?
This happened to a dodge I had once. The idle air control valve was sticking pretty badly so it wouldnt adjust to the rpms dropping from putting it into gear. I would try another IAC first. Let us know if that fixed the problem. You could always try spraying the hell out of it with carb cleaner for a temporary fix.
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
  • For sale 2g 1997 Mitsubishi Motors Eclipse Service Manuals
    1997 Mitsubishi Motors Service Manuals $50 for the pair + shipping & paypal fees* I priced...
