Can't figure out what this noise is,from back tire
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
i hear this noise from back my tire like a screeching sound its kinda hard to explain like something is rubing, i thought it was rotors chnaged rotors and brakes not that, now this doesnt always happen sometimes, like 1 or twice a week so like 20 sec just when i start driving like low speeds then stops someone told me wheel bearing?? what can this be
??????? :dsm:
I have a 90 GSX. I had a noise from the right rear. It was kind of a droning sound. At first it was only at certain speeds usually around 45. After 6-8 months it was all the time but most noticeable at 45 where it was like a loud whining growl. I knew it was the bearing since I could feel just a little play when I should the assembly. Kind of hard to decribe noises. It could be a bearing on its way out. I also had a whining squelling noise on same hub along time ago. It only happened when on a sharp turn to the right. Not noticing, I had bent the sheild a bit when replacing pads and for some reason it was only sometimes. Just on tight right corners. I just pushed on it through my wheel a bit and no more noise.
yea i guess its my bearing then it happens a low speed 10-40 just for like 20 sec or so could it be anything else?
CV?? Never had one of those go bad though so I don't know how they react. After rebuilding them I imagine it doesn't growl or moan. Just snap snap snap. I really think its a bearing. Jack it up and see if theres any play. Even when mine started going bad I could feel a little play.
    • george bromwell
    • pma1123
    • Sdcryan1
