Cant control boost...
Hazard
82
May 7, 2003
Swanton, Ohio
I just replaced my broken 14b with a "new" one from a local parts car as well as my transmission, clutch, and intercooler.
I left the downpipe unbolted from the o2 housing, i wanted to note this first to possibly save some reading below.
Anyways, i go out for the initial test drive, drive around for a few miles, come back to make sure there's no leaks after a normal drive.. everything looks great. (still not a single drop of anything after sitting in the garage overnight every night, amazing for a 212k original bottom end DSM)
so anyways, i took my boost controller off and hooked the vaccum hose straight from outlet pipe on the turbo to the wastegate, go out, wam 20psi... played with the wastegate for a while, nothing would fix it
so, i swapped my old wastegate on, 1st gear doesn't get far past 10 psi, every other gear still pretty much just goes way past 15 pretty quickly.
I haven't put my DP back on because the gasket was toast and i was just gonna wait to pick up another one and annoy neighbors in the mean time..
Any ideas would be appreciated. i didn't think running open o2 would cause this problem, but other than that i'm fairly stumped. I dont want to toast another turbo (or worse) anytime soon.
You're creeping. Bolt the DP back on and enable your mbc to turn up the boost more and you should be fine.
