Can't adjust idle.
90EclipsePos
76
Jun 22, 2014
Grand Junction, Colorado
Okay been working on this car forever and not having much luck after searching forever on how to fix this car I'm giving up and asking for your guys help. So I'm trying to adust my idle but no matter how much I unscrew the biss it will not increase or decrease the idle. It will kill the car once screwed all the way in but nothing else. I have done boost leak test, re-checked timing, new shaft seals, checked my isc and tps. What else could I be missing here.
My mods include: stroker kit, 880cc injectors, Maf-t, t3-t4 turbo, dsm chip. 272 bc cams.
So i did screw in my spring for the fiav rechecked throttle plate adjustment and after that i was able to adjust my idle up and down but after i unplug the jumper wires the idle still goes back to 1100 to 1200 rpm. Might be due to cold temperatures and blocking off the fiav also going to check again for boost leaks after taking off throttle body.
