Detail
Supporting VIP
- 524
- 134
- May 28, 2003
Marietta,
Georgia
I tried to contribute my question to the merged keyless entry posts but have not received any feedback.
First off I have a 95 (late 94 talon) tsi. It did NOT come with keyless entry. I DO NOT get the green security light when I lock the doors, I HAVE installed a 10amp fuse in the driver side kick panel for "security". I DO NOT have the factory hood switch (although the wire is there).
I have obtained two different modules for behind the passenger seat by the rear speaker. The first one was out of an avenger. The second one I sourced from a 97 GST. I have two brand new remotes from keyless ride. I also have a pin ground tool or a straight up piece of wire (jumper) or my dsmlink (put it diagnostic mode).
I have followed the directions to a T. I CANNOT get the doors to lock unlock after jumping and then flipping from off to acc and then to off.
All doors lock/unlock with key in outside of door or inside switches. WHAT IN THE WORLD AM I MISSING? There is zero aftermarket alarm in this vehicle. I DO have a turbo timer installed but I'm doing all of these tests with the parking break down so as to disable it (really turn the car off) when I cycle the keys.
From reading the merged post I see there are quite a few people with similar situations to my own. If you started with zero keyless entry and have made it work, please contribute.
Thank you in advance.
