CANNOT get 1g turbo oil feed line to stop leaking!
foxfan88
31
Apr 27, 2009
Miami, Oklahoma
Ive been having fits getting my stock oil feed to seal. Iv even gone as far as buying a new oil feed line (OEM) and new banjo bolts and copper crush washers (also OEM parts)
Didnt help. Took it all off and even filed on the top of the turbo where the washers sit and on the oil line making sure each surface is flat. Still no luck. It looks likes its coming from the top of the turbo where the oil line screws down but i cant think of anything else to do. I cant see anything in the area that could be leaking oil. Its almost like its something else leaking, as NOTHING i have done has helped at all.
Anyone ran into this problem and have any suggestions, i dont know what to try now.....
Try taking out the line and cleaning out the places that you screw them in at and see if the threads are messed up at all cuase if the threads dont line up perfect it can cause it to leak when it builds pressure and if they are messed up you may have to tap it and put in a new thread to screw into.
Get one of these. I just put one on my car to cure a leaking feed line. It's PERFECT!! They supply new crush washers, new banjo bolts, and all fittings...for $24 its one of the best investments I've made in my car.
1G DSM Turbo Oil Feed Line Kit: BoneHead Performance
If you ever have problems with your oil return, get this (I also have this on my car)...
Slowboy Racing, Inc. :: Mitsubishi :: DSM :: Do It Yourself Parts :: Misc. :: SBR Turbo Oil Return Line Kit (Pushlock Style)
++1 love this kit, my stock line had a small hair line crack in between the flex part of the pipe it was real hard to see
What lead up to this? Turbo swap, or..? Why is it that it was first removed? Has it always been this way?
