Can you upgrade dsm link v2?
It's not full price though? Another thing is it needs an oil pan put in. Is that going to be easy? I can't remember if anything was in the way to swap them
Sorry, didn't realize you were either blind or couldn't read. Here's the direct link to the upgrade page so you can see the price, since you couldn't find it in the link I already posted.
ECMTuning, Inc.
Try doing some searching about the oil pan. You're now starting to venture into going off topic from your original intention for this thread.
Exactly what you want for ECMLinkV3
To get the oil pan off you just have to drop the transfer case and pull the drivers side axle out of the transfer case. I think you can get it by the brace under it but might be worth it to just pull it as its only 4 or 5 bolts.
I just removed my oil pan last week. Its WAY easier to just drop the t-case. You don't have to drop it all the way though. Just unbolt it and swing it and the driveshaft out of the way slightly and set it on another jack or something so you don't have to completely drop it on the ground. You'll also probably have to unbolt your downpipe from the o2 housing to gain access to the bolts on that side.
