Can you make a homemade wideband
shadow001dsm
183
Mar 26, 2009
las vegas, Nevada
I have seached and searched and havnt found anything related to this. My question is wideband are a little out of my range right now and I thought i recalled someone saying that you can use a volt meeter gauge and another 02 senser. is it posible to make a wideband out of those?
Wideband has its own sensor. Different from the standard.
Narrowband O2 sensors are designed only to measure the stoichiometric air-fuel-ratio (AFR) for gasoline, i.e. 14.7:1. Wideband O2 sensors have a broader effective range of sensing. Narrowband sensors can only tell you when the AFR is 14.7:1. Although it can also tell you when you are richer or leaner, it cannot tell you by how much. A wideband O2 sensor can.Designed to measure a broader range of AFR (9.65:1 to 20:1), Wideband O2 sensors are more effective instruments for tuning your engine. They can detect variations of the AFR better than stock narrowband O2 sensors. The result is that you can tune your engine and modify your management system according to your use and performance level.
Huh, well not quite how you described it but still, interesting.
