boostboyike1
- 317
- 0
- Feb 25, 2004
springfield,
Missouri
my ball joints are bad mainly the compression ones and was wondering will urethane bushings help a little.and i already did the recall on the latterals.thanks!
boostboyike1 said:my ball joints are bad mainly the compression ones and was wondering will urethane bushings help a little.and i already did the recall on the latterals.thanks!
boostboyike1 said:No they dont.Anyway i replaced the ball joints. the laterals i took off and they seamed ok.but others were shot so i just replaced them but didnt help my problem.When i hit a bump i hear a loud clank sound and i can feel it in steering wheel ..also my steering feels"loose".both inner and outer tie rods are new to...thanks ..isaac
GVR4592 said:Don't urethane bushings cost more than replacement ball joints? Why the hell would you want to band aid a major suspension component with a part that cost more?
Eagle 5 said:Um, both ball joints are serviceable, you can go to Napa and buy the ball joints. However in my case, where someone before me decided it was a good idea to weld one of the ball joints in, I had to replace the control arm
