Can someone identify this motor mount for me?
smoothcustomer
Apr 22, 2008
Fairport, New York
Ok guys, I'm new to these forums so I'm not sure if this is the right place for this. I ordered a non-abs transmission side motor mount (this is for a Galant. On the Galant mount, it would have a bracket for the air can, which I don't have and on a DSM this would have an abs bracket, if it weren't otherwise specified) and it doesn't seem to match up to what I have that is certainly from an AWD car. I'm not totally sure if the mount on the left is from a Galant or an AWD DSM but it's one or the other. As you can see, it doesn't look as though these mounts are interchangeable. It looks as though the actual rubber bushing on the bracket on the right is "higher" than the one on the left. Can anyone confirm if this is from either a FWD, or AWD automatic car? I checked CAPS and it says there is a different part number for every variation for that specific mount. Thanks!
The mount on the left is from a galant GSX automatic car with ABS.
I know this because I had one in my hand, they other day when I was
at the junk yard.
I highly doubt this. A) I don't know where it would have come from B) the abs pump on a Galant is at the front driver's side. Can anybody post up a pic of a manual transmission AWD motor mount from the transmission side? I would like to see what you guys are comparing this too. Thanks!
Edit: Just to be clear, I want to know about the mount on the right in the first picture. I compared it just to check and the mount on the left is from a Galant VR-4.
