Can Some One answer My ????
eddie3_3
Jul 11, 2005
SAN PIERRE, Indiana
I have A 1993 Eagle talon it the shell right now and have a chance to get a 1993 eagle talon turbo the car engine is great condition has low miles but the body on the turbo is tottlay messed up bad it was in accident from the back tottally smashed gone i was wondering can i take the engien and all it parts and components and put them in my car thanks for you asnswer :thumb: :talon:
Yes its possible just make sure you take the ecu from the turbo car and all the wiring, im unsure if you might need a larger fuel pump as well, but its all possible as long as you switch over all the turbo wiring to your non wrecked car.Also you will need the tranny and all supporive drivetrain pieces.
your going to need more than the ECU. take the motor, the ECU and the wiring harnesses for all of the electronics, and pending on what you want to do with the car you might need new front drive axles for the power shift since there is going to be more power. your also going to need the intercooler piping and the SMIC itself, the fuel pump and the injectors. certain things need to be done correct in order to swap a motor the correct way...after all...its not a honda. :thumb: good luck man.
