Can i use stock dump tube with this BOV?
chr0n03939
66
Sep 6, 2004
Lake tahoe, California
hi, i got this hks standard bov, and i was told i could recirculate it. Can i use the stock dump tube with this bov? if not where can i get a tube that i can use.
(sry for the picture i dont have a scanner or a digital camera, but i did do a good job)
u talking about the stock recirc tube? if so i believe for the hks bov u need to get a recirc fitting....or make one urself, then you'll be able to get it recirc
From the crude drawing, yes you should be able to vent that. It does NOT appear to be any sort OF HKS BOV...
there is different types of hks bov's..
he prolly got the regular racing one
it should work unless ur bov is pointed the wrong direction... other than that you can get some tubing from autozone or similar that is like radiator hose but it can twist bend, however you like...
I bought the bomz cold air intake off of ebay and it has a small reciculation port on it, and the bov has the neck in a wierd position so i think i might need 2 90 degree bends in my return hose/dump tube. How would i hook up some pvc pipe to this? Does anyone know of any tutorials or pics? i found some custom ones on here but none with instructions.
looks like the old school HKS BOV from teh star turbo kits. If it is, no recir piece is needed, I do not think the stock s happed BOV hose will work, but check out Checker, autozone or whatever, and find a piece of radiator/heater hose that is premolded and has the inside diamter you need and cut it to fit
